Want more trusted info, so to TBN I go
   / Want more trusted info, so to TBN I go #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
I seem to have some problems with a left over file in my system.ini
Google came up with ErrorKiller that did a FREE scan and found 250+ errors/problems.
Does anyone have any experience with ErrorKiller, the free scan indicated it fixed 18 but I still have a "bunch" not fixed. Download full program $19.95.
Hope this is enough to get some helpful suggestions.
Thanks to ALL.
   / Want more trusted info, so to TBN I go #2
Watch out for that type of software. Could be spyware! You can go to Microsoft's website and download their Beta versions of Defender for free. Spyware is a growing problem, and is harder to remove than some viruses.
Read this article:
Spyware article
Joe
   / Want more trusted info, so to TBN I go #3
Microsoft Antispyware Beta 1 is a free download I've been pleased with.
Thanks for the suggestion Defender but if I read correctly that is for XP and I'm still 98SE. Guess it's time to upgrade, then the question is how far UP the grade do I go? /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif
   / Want more trusted info, so to TBN I go #5
Since you're running 98SE, you can use Spybot.
This link will take you to the site.
I've used Spybot for several years. Works pretty good, IMHO.
   / Want more trusted info, so to TBN I go #6
Those 'pop-ups' are B.S. I bet if you ran SpyBot S&D you would not have 250+ problems. They just want your $. The SECURITY TANGO website gives detailed step-by-step instructions {free} for a locate/kill/recover process that works great.
   / Want more trusted info, so to TBN I go #7
Also, Lavasofts' Ad-Aware is very good and is also free, don't know if it works with 98 tho. You should probably upgrade to XP SP2 either way..........
   / Want more trusted info, so to TBN I go #8
All of the above suggestions are great. My expirence is that not one solution is 100% all of the time. The best approach is to use two or three products. I usually use the SpyBot, Ad-Aware and the Micrsoft Anti-Spyware combo.
Of course like anti-virius software, these products need to be updated to be effective.
Goodluck. My wife one that I had to remove her hard drive from her machine hook it as a slave to mine (so that it wasnt a boot device) then clean it.
good luck
-dave
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2023 Caterpillar 299D3 High Flow XPS Compact Track Loader Skid Steer with Spectra Precision Laser (A52377)
2023 Caterpillar...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
201587 (A54756)
201587 (A54756)
