Want more trusted info, so to TBN I go
   / Want more trusted info, so to TBN I go #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
I seem to have some problems with a left over file in my system.ini
Google came up with ErrorKiller that did a FREE scan and found 250+ errors/problems.
Does anyone have any experience with ErrorKiller, the free scan indicated it fixed 18 but I still have a "bunch" not fixed. Download full program $19.95.
Hope this is enough to get some helpful suggestions.
Thanks to ALL.
   / Want more trusted info, so to TBN I go #2
Watch out for that type of software. Could be spyware! You can go to Microsoft's website and download their Beta versions of Defender for free. Spyware is a growing problem, and is harder to remove than some viruses.
Read this article:
Spyware article
Joe
   / Want more trusted info, so to TBN I go #3
Microsoft Antispyware Beta 1 is a free download I've been pleased with.
Thanks for the suggestion Defender but if I read correctly that is for XP and I'm still 98SE. Guess it's time to upgrade, then the question is how far UP the grade do I go? /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif
   / Want more trusted info, so to TBN I go #5
Since you're running 98SE, you can use Spybot.
This link will take you to the site.
I've used Spybot for several years. Works pretty good, IMHO.
   / Want more trusted info, so to TBN I go #6
Those 'pop-ups' are B.S. I bet if you ran SpyBot S&D you would not have 250+ problems. They just want your $. The SECURITY TANGO website gives detailed step-by-step instructions {free} for a locate/kill/recover process that works great.
   / Want more trusted info, so to TBN I go #7
Also, Lavasofts' Ad-Aware is very good and is also free, don't know if it works with 98 tho. You should probably upgrade to XP SP2 either way..........
   / Want more trusted info, so to TBN I go #8
All of the above suggestions are great. My expirence is that not one solution is 100% all of the time. The best approach is to use two or three products. I usually use the SpyBot, Ad-Aware and the Micrsoft Anti-Spyware combo.
Of course like anti-virius software, these products need to be updated to be effective.
Goodluck. My wife one that I had to remove her hard drive from her machine hook it as a slave to mine (so that it wasnt a boot device) then clean it.
good luck
-dave
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
