Want a smaller 00 tractor
   / Want a smaller 00 tractor #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I have been thinking of "my ideal" tractor and I have come to the conclusion that it is not being made. After studying I have in my head a smaller 4WD 00 series, built in India by Mahindra, 25-32 HP, wet sleeves-direct inject engine, 12 speed shuttle or hydro, wet brakes, 3k + weight but smaller framed and tight turning radius with a low as possible CG. I don't know if Mahindra is ever planning to make a smaller 4wd 00 but it would get my attention. I am very impressed with the larger ones but they are all too large for my needs and cannot justify getting one. I currently have a Kioti 3054 and I like it and will use it till I can justify getting something else. I hope by that time this tractor, or one as close as I can, get exists.
   / Want a smaller 00 tractor #3
Good luck in your search. Personnaly, I don't want to give up good ground clearance for somewhat lower CG, as I don't try to climb telephone poles with it anyway. BobG in VA
   / Want a smaller 00 tractor #4
I didn't mean that I wanted an exceptionally low CG but just lower than I had on my L3010 w/R4's. When I got the Kioti 3054 I was amazed at how much more stability it had because of the smaller frame, yet it has more weight and the same HP. I was just trying to design a 00 tractor similiar to what I have but with a few more things I want.
   / Want a smaller 00 tractor #7
</font><font color="blue" class="small">( I have been thinking of "my ideal" tractor and I have come to the conclusion that it is not being made. After studying I have in my head a smaller 4WD 00 series, built in India by Mahindra, 25-32 HP, wet sleeves-direct inject engine, 12 speed shuttle or hydro, wet brakes, 3k + weight but smaller framed and tight turning radius with a low as possible CG. I don't know if Mahindra is ever planning to make a smaller 4wd 00 but it would get my attention. I am very impressed with the larger ones but they are all too large for my needs and cannot justify getting one. I currently have a Kioti 3054 and I like it and will use it till I can justify getting something else. I hope by that time this tractor, or one as close as I can, get exists. )</font>
Sounds like a 3510o or 4110 would be just right for you. These beasties are heavier than their JD, NH or Kubota counterparts.
   / Want a smaller 00 tractor #8
Maybe, but those are built by TYM not Mahindra. I looked at 2810's which is the size I would really like and I thought they were nice. What I meant by "ideal" was if I could have what I really wanted. I want the 00 Series Mahindra features in a smaller package not a TYM or a Mitsubishi. I am sure they are fine machines but when, or if, I get a Mahindra that is what I would want. Wasn't trying to stir anything up.
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
J & M 30' Head Cart (A50514)
J & M 30' Head...
