Walking Beam Axle Trailer
/ Walking Beam Axle Trailer #1
JD 2140
New Zealand
John Deere 2140
I have an old walking beam axle ATV trailer. Please bear with me as I explain the problem, don't know much about trailers :eek:
There is a lot of play at the pivot point. I can move the beams up/down, side to side on the shaft. See pics below for all that negative camber.
What I need to know is what is required to get rid of the play?
Apologies for the poor quality photos.
/ Walking Beam Axle Trailer #2
You need a bushings. Machine shop should be able to make them either from bronze or teflon. Take the wheels off and bring the beam to them together with diameter of the pivot shaft. They should be able to press the bushings in.
/ Walking Beam Axle Trailer #3
Consider changing the pivot shaft also, it apears to be some wear on it too. Sorry for my bad eglish.
/ Walking Beam Axle Trailer #4
IMO one would need to redesigned your running gear. to more of a better supported axle system , something like in the drawing
/ Walking Beam Axle Trailer #5
Consider changing the pivot shaft also, it appears to be some wear on it too. Sorry for my bad English.
I agree with Tor Arne, replace the axle stubs and put in bushings. while you are at it a grease zerk on each axle as that is likely the cause of your trouble, lack of lubricant
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
Generator on Trailer (A64119)
Generator on...
2016 International DuraStar 4300 S/A Dump Truck (A61573)
2016 International...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
