Wacky Tach (3840)
/ Wacky Tach (3840) #1
hlpdobro
Frederick Co MD
Montana 3840
Tach on 3840 is jumping around. I suspect the cable. Is there a practical way to lube or should I seriously consider replacement?
hp
/ Wacky Tach (3840) #2
Don't lub the cable!!
I had a similar problem. I took the cable apart and found nothing wrong with it. The problem I found (and I suspect is yours) was dirt in the tach. Take the dash apart and remote the tach head. CAREFULLY blow the tach out. I believe you will find this will fix your problem. The clearances inside are very tight and small bits of dirt cause it to bind and bounce. My tractor is 14 years old and works like a charm now.
Good luck with it.
Glenn
213137 (A64276)
213137 (A64276)
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
