Wacky Tach (3840)
   / Wacky Tach (3840) #1
hlpdobro
Frederick Co MD
Montana 3840
Tach on 3840 is jumping around. I suspect the cable. Is there a practical way to lube or should I seriously consider replacement?
hp
   / Wacky Tach (3840) #2
Don't lub the cable!!
I had a similar problem. I took the cable apart and found nothing wrong with it. The problem I found (and I suspect is yours) was dirt in the tach. Take the dash apart and remote the tach head. CAREFULLY blow the tach out. I believe you will find this will fix your problem. The clearances inside are very tight and small bits of dirt cause it to bind and bounce. My tractor is 14 years old and works like a charm now.
Good luck with it.
Glenn
378789 (A51572)
378789 (A51572)
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
22008 (A51694)
22008 (A51694)
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
