W6x15 I beam load calculation needed
   / W6x15 I beam load calculation needed #1
Woody65
East Northport and Oneonta NY
John Deere 4300 HST 4wd
I can’t seem to find a load calculation chart for a w6x15 steel I beam at a 20’ span. The load would be distributed ( tractor, atv, utv, etc). Beam will be supported on both ends. Specs are as follows: area-4.43, d-5.99, bf-5.99, tf-.26, tw-.23, lxx-29.1, lyy-9.32 Thanks
   / W6x15 I beam load calculation needed #2
For some reason, that beam wasn't in my book of tables, but the weight capacity (evenly distributed, simply supported at the ends) is W = 8fS/l where f is the fiber stress limit (20,000 psi is a good estimate), l is the length of the beam in inches (240 in your case) and S is the section modulus in Inches cubed. After poking around I found a value for S for this wide flange beam of 9.7 in**3. Plugging this in, I get about 6500 lbs. Remember, this is really evenly distributed. Unless you have a good floor solidly distributing the load, I would back off. The point load capacity would only be half the distributed load capacity.
You should double check all this, but I think it makes sense.
   / W6x15 I beam load calculation needed #3
   / W6x15 I beam load calculation needed #5
A W6 spanning 20' would concern me. It will deflect. Possibly much more than you or someone would find acceptable. You also need to make sure the beam is laterally braced, or it may buckle. Stresses are reduced based on bracing configuration. I would be much more inclined to use a W10 or a W12 with a 20' span. Good Luck!
Yooper Dave - retired professional Structural Engineer
   / W6x15 I beam load calculation needed #6
Active load like a vehical crossing and static one are quite different not to mention lateral bracing as Dave mentioned is very important. (arm chain engineer)
   / W6x15 I beam load calculation needed #7
Determine your loads, determine dynamic effects, determine bracing. THEN determine the maximum moment, Allowable bending stress, actual bending stress, and deflection(s). Might be worth hiring a structural engineer if the beam is important to safety.
This thread is 6yrs old. If you want to see the finished product go to a thread of mine called “ finally got the bridge started”. I wound up going with (4) w12x25 beams. It turned out pretty cool. Thanks for the responses.
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
