W.R. Longs plow setup
/ W.R. Longs plow setup #1
pdrrock
kubota b26
I settled on this plow setup for my Kubota L2800. I would like to keep the backhoe on it for the winter. I need to bring Hydraulics in for the plow and althought W.R. Long gives you everything you need, I thing they expect you to use the ports on the block that your already using for the backhoe. My question is can you use those other ports that have plugs in them on the block thats under the body at your left foot. Or do you have to T into the lines. Thanks
/ W.R. Longs plow setup #2
First, you can not "T" into a pressure line. You can divert the pressure... W.R. Long (I think) uses the curl of the FEL... I would call W.R. Long and find out. Did you get any instructions with the kit?
I thought that was what the block was, under the body at your right foot. Some type of diverter with extra ports. I'll call W.R. Long and Kubota. Thanks.
/ W.R. Longs plow setup #4
Is this the block you are talking about... See photo. I'm assuming that you are using the electric hydraulic diverter from Long??
Yes that's the block I am talking about. I will be useing the electric over hydraulic valve kit that they will supply. I haven't ordered it yet because I wasn't sure if I could leave the backhoe attached and use the ports that are plugged on the junction block to bring oil to that valve or would I have to come up with something else in order to be able to power both. Thanks for the diagram.
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2022 EZ-GO ELITE...
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
