W.R. Long Inc. Grapple Problem
   / W.R. Long Inc. Grapple Problem #1
bgtrck458
NH
Massey 1635 cab / kubota B8200D / 2001 Bobcat X331
I recently purchased a 60" grapple rake from W.R. long through a local dealer. The model is the RBG 2 which is designed for compact tractors with a lift capacity under 2k. I run a small cord wood business and use the grapple for moving logs and the slash generated from felling and processing trees. The grapple is mounted on a 2010 Massey 1635, which the sales person from W.R. Long assured me was exactly the size tractor they had designed this grapple for. With less than 5hrs. on the grapple I can tell you it is VERY poorly manufactured. I had broken one tooth off the grapple and bent another in less than one hour. I could not believe an implement advertised as being able to remove roots from the ground couldn't even handle some branches. I figured I must have hit a large rock I didn't see and the damage was from operator error. WRONG. Upon inspection of the remaining teeth I found they were only tack welded to the frame of the grapple. I couldn't believe it, several of the welds didn't even contact both pieces of metal. Not poor penetration, NO CONTACT AT ALL. I paid 2135.00 for this thing with shipping and I am going to have to do probably 5 hours of prep and welding to get it through 20hrs. of use. I can't believe a company with such a long history and good reputation could have such terrible quality control or poor engineering. has anyone had any experience with this product? Is there a similar grapple for around the same money which isn't trash?
   / W.R. Long Inc. Grapple Problem #2
Did you call them and let them know? Give them a chance to make it right.
   / W.R. Long Inc. Grapple Problem #3
Agreed...Sounds to me like it wasn't finish welded yet. Shouldn't happen, but it does sometimes.
   / W.R. Long Inc. Grapple Problem #5
I go along with gpflepsen, contact them and tell them why you are not happy. :( Take it back to the local dealer and ask for your money back. They should stand by what they sell. Take pictures of the problem areas and send them to the manufacturer as well.
i will post some pictures when I get the tractor back from the shop. It is in for some warranty work right now. I was supposed to have it back today, but haven't heard from the dealer yet. I am sure I could stir up some concern at the dealer, but it really isn't their fault. I contacted them because they were the only dealer around that could get W.R Long attachments, I asked them to order it for me, and I have no complaints with anything they did. I also think that W.R Long would probably have no problem taking the grapple back and repairing it. But I doubt they would cover the $300 shipping each way, and the weeks of downtime would kill my spring time cord wood sales. I guess I am looking more to warn people about this product, and to see if anyone has had similar problems with a W.R Long grapple, or a more positive experience with this grapple or another one.
   / W.R. Long Inc. Grapple Problem #7
Before you continue bad mouthing W R Long, call them and don't assume what they will or wont do to make this right. Mfgr bashing violates TBN Terms Of Service.
I am Sorry Mike, you are right I do Need to contact W.R Long and see what they will do to make things right. But it is Monday night and that can't happen until tomorrow. If my complaining is considered MFG. bashing then I will not continue. I am not trying to say that W.R. Long is a bad company, I hear great things about their valve kits and other products. My complaint is that no matter what any company is willing to do, at this point any correction to my problems is going to cost me time out of my days, which translates to money out of my pocket, even if there is no direct outlay of money. If you bring your car to the shop and the wheel falls off after they repair it, it doesn't matter if the shop pays for the tow, and fixes the wheel, and even if they brought you a rental car for free so you could continue with your day. It is still costs you time, which you can't get back.
   / W.R. Long Inc. Grapple Problem #9
Perhaps a different place to vent your frustrations would be appropriate, after you get over your lost time I am hoping you will come back and tell us what a great job W. R. Long making it right by you if that is the case.
   / W.R. Long Inc. Grapple Problem #10
I have the 48" RBG 2 Grapple on my tractor now. Had been using it to move a lot of brush and logs from the house we are building. No problems with mine, and a few times I wasn't very gentle in moving the logs or building the burn pile.
Sounds to me like 1 bad grapple got through MFG line. Even car & truck MFG get lemons out in the market. I have no doubt that Nelson will take care of the problem. Actually, I have been so pleased with the grapple, I just ordered a 4N1 bucket last Friday.
UNUSED LANDHERO CHAINS, BINDERS & DBL CHAIN SLINGS (A54757)
UNUSED LANDHERO...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Informational Lot - Financing (A55302)
Informational Lot...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2010 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A54607)
2010 MITSUBISHI...
