VW Clean diesels.... how did they get them so clean?
   / VW Clean diesels.... how did they get them so clean? #512
I wonder if there is an opportunity here, given that the selling price of the affected vehicles has dropped. Pick one up cheap, take the $10K and have VW re-emissionize it??
   / VW Clean diesels.... how did they get them so clean? #513
Although there is no information on this type of bargain hunting I rather doubt the VW lawyers failed to take it into account. I wonder if there is a minimum time of ownership or ownership before the EPA news broke or something like that. Otherwise you could simply buy up a junker and get average retail price as of Sept 2015 plus $10K bonus. Seems unlikely.
   / VW Clean diesels.... how did they get them so clean? #514
Perhaps they will require you to have owned it for x months (like the government did with Cash for Clunkers)?
Aaron Z
   / VW Clean diesels.... how did they get them so clean? #515
VW will do what BP did after the gulf spill, pay large law firms rather then pay claims and it will go on for many, many years.
mark
   / VW Clean diesels.... how did they get them so clean? #516
On the other hand, if you need to pump water, you could acquire one of these "firesale" VW's and extract the diesel then use it to power your water pump or an old tractor (if it isn't too big).
(Where I live, a lot of water wells are now being drilled down to 600' so they can ensure they can actually pump water. My well is only drilled to 160' with the submersible pump set at 90'. When I first moved to NM, the water table was 8', now it's 30' and getting deeper. Ten years of drought doesn't help nor do the higher temperatures; it cooled down yesterday due to rain but the 4th we'll be back in the 100+ temperature range. Of course, I'm better off than Phoenix, AZ -110+. )
   / VW Clean diesels.... how did they get them so clean? #517
It sounds like if the sale happened AFTER the problem hit the news....the new owner and the previous owner SPLIT the money.
   / VW Clean diesels.... how did they get them so clean? #518
The major problem would be designing a governor to regulate throttle settings depending on the load. Without that...it is worthless.
   / VW Clean diesels.... how did they get them so clean? #519
Maybe not exactly worthless. If the hp produced at idle setting was sufficient to run the water pump then it would work. ?no? I rather doubt the max hp would be needed ever in such a setup.
   / VW Clean diesels.... how did they get them so clean? #520
Drive it through the transmission and use the cruise control to set the "pto speed".
Aaron Z
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
2008 CAT 305C (A53317)
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
(2) CASE IRON POT BELLIE STOVES (A58374)
(2) CASE IRON POT...
