VOM 101
/ VOM 101 #22
/ VOM 101 #23
if your tractor has a brush type generator and / or a breaker ignition system.. might as well leave that sensitive DVM at home and break out the cheap analog meter.. ya know.. the ones with a needle.
sample rate on most consumer grade DVM's is not compatible with brush/noisy lines.. and you can get eratic readings. genny based charge systems tend to use the averaging principle with a vibrating mechanical regulator that quickly alternates between max charge and low charge as the points open and close int he vreg field circuit, with a large value bias resistor across the contacts to provide somefield current with the points are open. those switch in / out spikes really aren't conducive to accurate readings.
add to that a rx1 setting on an analog makes a great points and or condensor tester.
In an energized circuit all you really need for trouble shooting is a sensitive Digital Volt Meter - and theyre all sensitive enuf for tractor work:) . The ohmeter part will get in trouble by being burnt up in a live circuit and even when used right is mostly worthless for measuring low resistance.
http://www.tractorbynet.com/forums/parts-repairs/102900-starter-circuit-problem.html
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
CHRYSLER V8 GAS ENG (A63291)
CHRYSLER V8 GAS...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
