Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,871
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
Mini excavators, that is...
Looking for a ME in the 7000# range for general landscaping, clearing silt from ditches, maintaining logging roads, clearing stumps and downed trees, etc. Considering these babies are made for construction it will have a relatively easy life with me. I used a Kubota KX71-3 last summer for two months, and it was just a tad too weak for some of my tasks. The KX121-3 is physically too big for some of my land...so the KX-91-3 looks like a good compromise in size.
The Volvo version would be the EC35. It's heavier, has more HP, a good reputation, and one ton LESS bucket breakout force than the smaller Kubota. I could say the same thing about the Bobcat products in that range; you really have to go up to a 10k# machine to get the breakout force of the Kubota.
So a few questions...
Is HP as important as weight and breakout strength? Seems like more HP is better, but if it can't dig as well where does all that power go? And if you have a light machine with tons of breakout power, won't the machine just get tossed around or critical parts wear prematurely..?
The Volvo and Kubota make more use of steel hydraulic lines, using rubber only at flex points. More protection, but also more connectors. Is that okay? They also have better fit and finish than the Bobcat, but how important is that on a construction machine? Or is it indicative of quality in other areas as well?
