volume of 72" fel bucket
   / volume of 72" fel bucket #2
Length x width x depth........27 cu ft is a yard.
   / volume of 72" fel bucket #3
Heaped, the bucket holds about 13 cubic feet. I think if you really heap it, you can get 1/2 yard in there. The struck quantity (non-heaped) is about 11.5 cubic feet. If you need exact numbers, I can look them up.
   / volume of 72" fel bucket #4
It really depends on the shape of the bucket as well. I have 2 different 84" buckets and one will hold almost 30% more than the other as it's much deeper. I can get right at 1 yard heaped in the one bucket but not close to that much in the other. I almost forgot; my 4 in 1 bucket holds even less with it's design.
   / volume of 72" fel bucket #5
You don't need a calculator to get these numbers. NH engineers already have this all figured for you and publish it in their loader manuals.:dance1:
72" HD or STD = 11.9 cu. ft (.44 cu. yd) struck, 13.7 cu. ft (.51 cu yd) heaped
72" HD QT = 13.1 cu. ft (.48 cu. yd) struck, 13.7 cu. ft (.51 cu.yd)heaped
And the std bucket weighs 286 lb and the QT 289 lb. You don't have to put them on your bathroom scales to find those numbers either.:rolleyes: :laughing:
Thanks everyone! I'm putting together volume and weight capacities and need to know how much stuff I can move and lift with my setup.
Jinman, while we're on the subject: I weighed my bucket + cutting edge + tooth bar at 390 lbs. I've discovered this to be a crucial piece of data since the 17LA FEL specs say it lifts 1545 lbs. to max height 19.7" in front of pivot pin. So I can only hope to lift 1155 lbs., minus chain weight, all the way up.
I was upset to be unable to lift my 758C backhoe (weighs 1200 lbs.) more than 2 ft. i.e. couldn't get it up onto my truck. by the way there are no handy attachment points for chain on the hoe and it's extremely unwieldy:(. I've got some challenging transport problems now that I went and filled the rear tires on the TC40D :confused2: I have to move components separately to stay legal!
   / volume of 72" fel bucket #7
I can identify with everything you are saying. I quit hauling my tractor after I loaded my tires. If you want to lift your BH, I'd take the bucket off the loader and just use the cross torque tube as a lift point. It will get you closer to your pins and give you that extra amount of lift you need. Who says you have to have a bucket on to do lifting? Buckets are for digging in my book and I pop that thing off when I need to do serious lifting. My suggestion is to give it a try without the bucket.
Excellent idea :thumbsup: I'll use a rated nylon lifting sling so I don't scuff on the crossbar. I hope the load doesn't swing in to hit the tires or fender.
Thanks,
Chris
   / volume of 72" fel bucket #9
As much as you can, keep the load on each end of that bar instead of in the middle. I think it is plenty strong, but a little care can ensure it isn't damaged. Oh yes...I'm talking about the torque tube between the quick attach adapters, not the big blue one between the loader arms. That big blue one would be pushing your luck for close to the hood.
   / volume of 72" fel bucket #10
On the legal side, do you get stopped and weighed much? Can't see DOT really being a big worry.
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
