Voltage regulator?
   / Voltage regulator? #1
bmartin172
Flintstone, MD
2019 Mahindra 4540 and 1986 Ford 2110
1986 Ford 2110. Head lights, fuel level and temp gauge all stopped working suddenly. Any ideas? Voltage regulator?
   / Voltage regulator? #2
What voltage do you get with tractor off and how does that compare with tractor on? do you get any voltage on temp sender? did you check fuses any? as the name implies voltage regulator work along with the alternator to " regulate" good charging voltage. That should not directly effect gauges. need to dig in more.
JC,
   / Voltage regulator? #3
If the tractor starts and runs normally I would look for a main fuse or possibly a defective ignition switch. Of course if it's not charging the battery will eventually go dead from starting the tractor.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
KOBELCO SK210LC EXCAVATOR (A55745)
KOBELCO SK210LC...
2013 PETERBILT 367 (A55745)
2013 PETERBILT 367...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
