Volt Meter, Clock, Filter Monitor install
   / Volt Meter, Clock, Filter Monitor install
3RRL said:
Larry,
.........I have a question, since it has a reset, if your filter starts clogging a little, say 1/4 of the way, when you start working the next day will the filter minder show more clogging or do you have to reset it from the first 1/4 reading?
Rob,
It does not have to be reset, if you want to, you can reset it, but it will just go right back to reading 1/4 restricted as soon as the engine is started. Otherwise the reading will hold at 1/4 restricted, the indicator will progressively climb and lock into place as the filter becomes more and more clogged. When it reaches maximum, time to change or clean the filter, at that point you reset it to start the cycle over again.
3RRL said:
......Oh, and I noticed the quartz clock had no second hand? LOL ... what's up with that?
No Second hand - yea thanks for noticing, I could not find one that has it :confused: If anyone knows where to find a 2" panel mount clock with a second hand let me know.
Thanks for your compliments.
Larry
   / Volt Meter, Clock, Filter Monitor install #12
Mornin Larry,
Very nicely done with a nice clean layout ! Funny you should post something about air filters, I was just thinkin I havent checked mine in awhile ! ;) That guage would certainly take some of the guess work out of that little bit of maintainance !
Although Im like Rob, what no second hand ! ;)
Keep up the great ideas ! :)
Scott,
Thanks for the kind comments, but geeze all this heat over not having a second hand, what a tough crowd. No one complained about the volt meter not being able to indicate millivolts :confused:
OK I went back and took another look at the clock, I decided it does in fact have a "second" hand - see for yourself->
It never occurred to me not knowing what time it was to the exact second while on a tractor was that important, apparently I was wrong. Maybe I should look for an Atomic Clock with calender and phase of moon accurate to one billionth of a second :rolleyes: , sheesh.
Larry
   / Volt Meter, Clock, Filter Monitor install #14
If you do the atomic clock upgrade; make sure you get a Starrett Machinist's Level for a tilt meter. :rolleyes:
Oh just great, Although I do admit, I did search eBay for an aircraft horizon indicator complete with gyro - now that would be the perfect tilt meter!
Larry
   / Volt Meter, Clock, Filter Monitor install #16
Yeah Larry,
I have a couple of them and could send you my spare if you want? They are kind of pricey as I recall.
   / Volt Meter, Clock, Filter Monitor install #17
Larry
Don't forget the timer function so we'll all know exactly how long one of your projects take. :D
3RRL said:
Yeah Larry,
Rob,
Only you could whip out one of those from your bag of tricks. Is there nothing you don't have? Thanks for the generous offer, I'm afraid I would not know how to use that, so you better keep it for a tractor project you have not yet conceived.
BTW Rob I see your desk is off level by a huge amount, better take care of that right away. I have some spare books of matches I could send you, place one of them under the leg. I got them at the Holiday inn so it wont set be back (much).
Larry
TL - Oh swell, should I include all the additional time it takes to shoot the photos, size them to 640X480 pixels, upload, and post the narration so I can take and respond to all this abuse? :rolleyes:
Larry
   / Volt Meter, Clock, Filter Monitor install #20
Larry
I like the idea of the artificial horizon. Make sure you get a stall warning indicator too so when climbing steep hills you'll get that melodious noise indicating imminent danger is present.
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A57024)
2019 RAM 5500...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
Tandem Axle Rear Trailer Frame (A55852)
Tandem Axle Rear...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
