Visited my Toolcat yesterday! (Pictures!)
   / Visited my Toolcat yesterday! (Pictures!) #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
I was at my dealers yesterday to look at my Toolcat and was also able to compare it to the B series, since he also had a used B on his lot.
This first photo shows the difference in how the rollback cylinder is attached to the boom. It is attached much higher in the C and also looks more substantial. It also shows the change in the boom itself. In the B, it is a single tube shape, whereas the C has double members.
  • 756959-1Curl Cyl Attach.pdf
These next photos show the difference in the way the attachment mounting plate is attached to the boom.
  • 756963-2CurlToBoom.pdf
Here are the glamour shots.
  • 756964-3My Unit.pdf
   / Visited my Toolcat yesterday! (Pictures!) #4
Rolando, be sure to get them to sell you a couple of replacement hydraulic hoses with proper fittings for those on the FEL, you will need a couple per year when they get ripped off while you are using them.
Here are more shots that show the bouble boom in the C series.
  • 756971-4Doub Memb Boom.pdf
Thanks, Thom, I will.
Here's a shot of the cab and another of the FEL boom.
  • 756977-5Cab & Boom.pdf
   / Visited my Toolcat yesterday! (Pictures!) #8
I just thought that I would warn you. Last Sunday, I was at the end of a stump removal job when all of a sudden oil started spraying all over out of the backhoe bucket cylinder. Right at the end of the job I had ripped the 3/8" 3,000psi hydraulic hose right off the adapter on the bucket hydraulic cylinder. No harm done to the adapter attachment to the cylinder or the hydraulic cylinder, but the hose was toast.
I emailed Ronnie Bowman @ TractorSmart Sunday night when I started feeling queasy about Hurricane Wilma and the fact that one of my cherished Kubotas was out of commission. Ronnie Fed-Xed me a replacement and I received it and installed it last night, less than 48 hours of downtime after the mishap. Did loose about a gallon of hydraulic fluid too.
That's why I warned you, it only happens when you are working and when you need it most! /forums/images/graemlins/grin.gif
BTW, your machine looks great, but you'd better get that L-3030 for a back-up! /forums/images/graemlins/wink.gif
Here are shots of the dash showing the keypad for the Keyless Start Security System, and the switch panel for functions such as the bed dump and the steering mode.
  • 756979-6Dash&controls.pdf
Here are the last shots for now. It shows the location of the radio in the ceiling, if anyone's interested. Sorry about cutting off part of the radio on the close-up. This is my first time using a digital camera, and I felt more comfortable using the view finder instead of the LCD. Unfortunately, I'm also used to SLR cameras where the view finder works through the lens and forgot that the digital camera doesn't work the same way, so the viewfinder doesn't give you the same picture the camera is taking with close-ups.
  • 756986-7The Radio.pdf
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
2007 Chevrolet Suburban 2500 4X4 (MPV), VIN # 3GNGK26K97G305720 (A48836)
2007 Chevrolet...
Bush Hog 306 72in. Commercial Mower Attachment (A49346)
Bush Hog 306 72in...
2019 John Deere 317G Track Loader (A50490)
2019 John Deere...
2022 Club Car...
2015 JOHN DEERE 624K WHEEL LOADER (A50458)
2015 JOHN DEERE...
