Virus causing my hard drive to run constantly?
   / Virus causing my hard drive to run constantly? #31
Hard drive churning is not a common symptom of malware infestation. My first thought would be imminent hard drive failure. My first step would be to verify the hard drive is working correctly by booting into the BIOS and check to see if there are some hard drive diagnostics built in. Most PC's usually also have some kind of restore or diagnostics partition that can be booted to to run diagnostics.
If it some kind of malware infestation, it can be very tough to get rid of. There is almost no 100% chance of being certain all threats have been eliminated. The only way to be 100% sure the PC is not compromised is to reformat the hard drive.
First step to take once you think a virus has taken control of your machine is to run scans on the hard drive without booting from it. There are several ways to do this. I usually use Aviras Rescue CD. Download the image from here: Avira AntiVir Rescue System - Download and choose the 2nd file for download, the .exe. Best practice is to use a second computer to create a CD using this download. Then boot the suspect computer using this newly created CD. It is a standalone virus scanning system.
Another tool to use to isolate the suspect hard drive is one of the many "Live" CD's for Linux distributions. I recommend Ubuntu. Using this CD you can access the problem PC's hard drive and be able to run diagnostic, edit files and most important copy off files that you want to save with reduced chance of transferring the malware also. Again you'll likely need to use a 2nd PC to create this CD.
Once you have some control back on the suspect PC I recommend running full scans with your anti-virus system Malwarebytes, super anti-spyware, IOBits Malware Fighter. Be aware that all this will take many hours to complete.
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2008 HINO 26FT NON CDL BOX TRUCK (A58018)
2008 HINO 26FT NON...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
Ford 8340 (A53317)
Ford 8340 (A53317)
