Vintage Ford 3400 tractor won’t start
   / Vintage Ford 3400 tractor won’t start #11
One very important thing I can add is about the filter..
Maybe you’ve run into this in your journeys around the web..
IF u have the 3 pc filter set up, filter head, filter, glass bowl with the long screw that holds it all together..
If your using a NAPA OR WIX FILTER..
THE TOP ORING MUST GO “UP IN” The filter head..
NOT “ON” THE FILTER..
It looks like it goes “on” the filter..
Otherwise it’ll choke off the fuel..
If it ran before u started working on it and then changed the filter and didn’t pay SPECIAL ATTENTION TO THE TOP ORING.. u might have built in a problem..??
It’s worth a 2nd look..
Good luck
   / Vintage Ford 3400 tractor won’t start #12
My 3000 (175 ci) had a Simms inline, My 550 (201ci) has the CAV distributor type. Both 3 cylinder Ford diesels. Ford definitely used both types on the 3 cylinder diesels.
Thanks for the info.
   / Vintage Ford 3400 tractor won’t start #13
Thanks gents!
I’ll get busy and get Old Daisy up and at it!
I finally brought home the service manual for the 2000,3000, and 4000 series. I don't know if it can help you, but I have it if you need it.
The members who have already posted can probably offer more, however. 👍
TEST YOUR BID BUTTON! (A57192)
TEST YOUR BID...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
