Victor Fluid Power Control valve replacement/upgrade
   / Victor Fluid Power Control valve replacement/upgrade #1
L245DT_NY_Drew
Hi every one, I am new here and have a few questions. I own an L245DT with a 1200 series loader, and the control valve is a Victor Fluid Power unit. I have looked into replacing the unit with a newer one, but have been unable to find one. Any suggestions?
Also, the unit has seven lines attatched to it, and every other unit I have looked into has only 6. The dealer quoted me 1400.00 to replace the unit, (a little steep if you ask me).
Thanks in advance for any help.
Drew
   / Victor Fluid Power Control valve replacement/upgrade #2
The older Kubota loaders were made in the US - I think mine had a Cross two-lever, 2-spool valve. There are nomally 2 lines for up/down, 2 for bucket curl forward and back, and 2 more for hydraulic supply and return. Can you post a pic of the loader and/or valve? - need to know where they all go. Some possibilities for the 7th line are external relief valve (would lead to a T in the return line) power-beyond (to supply hydraulic fluid to something else), regenerative make-up for faster FEL motion. $1400 sounds steep to me too. The valve can be had for $300 including built-in relief. Example at eBay: Joystick Hydraulic Valve Not sure what else the dealer thought needed replacing - are the hoses ok? Does the valve mounting need to be re-invented?
Take care, and welcome to TBN - Dick B
   / Victor Fluid Power Control valve replacement/upgrade #3
I have the same question. I have a L295dt with victor fluid power valve with 7 hoses, can't find any info on it and want to make sure a valve I order will work
   / Victor Fluid Power Control valve replacement/upgrade #4
Seven hoses indicates the valve has power beyond feature which is common on FEL valves today. You may have to order a power beyond plug or sleeve for the valve so make sure the valve you purchase has this option available.
With a little research I am sure you can find a valve with ports pointing similar location so minimal mounting change should be required.
   / Victor Fluid Power Control valve replacement/upgrade #5
20704 (A55853)
20704 (A55853)
(2) CRAFTSMAN WORKSTATIONS (A58374)
(2) CRAFTSMAN...
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
(2) 225/75D15 TIRES W/ 5 LUG RIMS (A52708)
(2) 225/75D15...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
1837 (A58374)
1837 (A58374)
