Grading vibration when lowering box blade
   / vibration when lowering box blade #1
stwyatt
oklahoma
Kubota L2959GST
i'm still getting used to my dk45se, compared to my old tractor. One thing i've noticed is when i'm using the box blade, and only want it part way down, the thing vibrates(for lack of a better description) violently. it won't stop until i lower the blade all the way. same thing, if i raise it slowly and try to stop midway, it does the same thing. what am i doing wrong?
   / vibration when lowering box blade #2
Your using the wrong lever.
Don't use the draft lever... use the other one.
lloyd
   / vibration when lowering box blade #3
to control position it can be a little tricky. (when I start my tractor my levers are both all the way down). You have to move the draft lever all the way up, then the position all the way up. Then drop the draft all the way down (the implement will only move a couple of inches and not all the way down). Then you can use the position to control the height.
Once you get the hang of it, it will be easy. I had to actually think about what I do to use it that way. It will become second nature in no time.
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2014 Dodge Charger (A50324)
2014 Dodge Charger...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
