Vibration in Woods rotary mower
   / Vibration in Woods rotary mower #1
MESSMAKER
Bluegrass,KY
DK4710SE
I am noticing some vibration that I can feel in the steering wheel. It seems to come and go or at least is more intense at different RPMs. I have checked the blades, but seem to look OK. The stump jumper has a couple small dents, but nothing major. I am beginning to think that maybe I have a bent output shaft. How do I check this? What else could it be?
   / Vibration in Woods rotary mower #2
Remove the shield and spin the shaft. Have you checked the bearings in the gearbox or spun the cutter by hand and watched for anything not looking true?
   / Vibration in Woods rotary mower #3
I don't have a Woods brush cutter.. but I did pick up a small piece of fence wire at one point. Was just enough to get under one blade and slow it's spin. I would hit a larger piece of brush and it would take a while for the mower to spin that slow moving blade back out.. Vibrations would ride through the tractor.
I finally crawled under and checked things in detail.. found the one blade not wanting to spin freely. Took it apart and found the small piece of wire wedged between the blade and the stump jumper plate.. removed the wire, re-assembled, and no more issue.
Could you have something like I had?
   / Vibration in Woods rotary mower #4
Could be a flat section worn on the drive belt.
   / Vibration in Woods rotary mower #5
Bad U-joint(s) in the PTO shaft?
Bent PTO shaft (from raising too high and shaft hitting deck) The shaft could be bent inside the shield and not look bent with the shield on.
If the output shaft is bent, you might see the blades and/or stump jumper not following a lever path. DO NOT CHECK WITH TRACTOR POWERING THE CUTTER! Have someone turn the PTO shaft while you watch.
   / Vibration in Woods rotary mower #6
Not sure what model woods you have, but my 6ft rotary was bad about vibrating. The blade pivots would stick a little and make one blade slightly off center. If I mowed over some limbs or a small tree or something to shake it around, it would smooth out. Check those bolts that hold the blades on and make sure they're not rusted. Grab each blade and make sure it swings freely. Squirt some power blaster in there to loosen it up a little.
   / Vibration in Woods rotary mower #7
A little vibration is normal. It’s a tractor and a Bush hog.
Come on mannnnn!
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
Toro Z-Master 7000 Series 70in Zero Turn Mower (A50322)
Toro Z-Master 7000...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
