Vevor Hydraulic Top Link
   / Vevor Hydraulic Top Link #1
Farmer495
Nova Scotia, Canada
CaseIH / MF / Kubota
Anyone have one? I was going to assemble one from parts and saw them on Amazon (CDN money)
   / Vevor Hydraulic Top Link #2
I can take a few pictures, no problems so far and does not sag down.
   / Vevor Hydraulic Top Link #3
If I was to buy one of these could I just plumb a valve to the power beyond port in my loader valve? And then does this valve that I just plumbed in drain into the sump, like the loader valve? As an aside, even though I don't have one of these Vevor cylinders I do have a Vevor submersible well pump, sausage stuffer, and vacuum sealer. All 3 perform very well, I am impressed with the quality.
Eric
   / Vevor Hydraulic Top Link #4
I got mine from Princes Auto. Can’t comment on price but it has worked well for at least 8 yrs now. (They still do mail order). They used to make there hydraulics in Canada, not sure if that is still true.
   / Vevor Hydraulic Top Link #5
You would need to install a control valve on the power beyond line from the loader valve and then feed the discharge port of the new valve, to wherever the power beyond goes to now, to complete the circuit. Does your tractor have a rear remote? Or can you get a kit?
Princess Auto has them on sale (minus the hoses) By the time I buy all the fittings and assemble it myself it's more money than the completed Vevor one and wouldn't have the leak down valve.
I'll have to check where the PA cylinder is made, might be better for longevity.
   / Vevor Hydraulic Top Link #7
My tractor does not have a rear remote and I don't plan to get one. It seems like I just need a two way valve to extend or retract the top link cylinder and then tee the discharge into the power beyond line coming from my loader valve.
Eric
   / Vevor Hydraulic Top Link #8
Eric
To control a cylinder or an hydraulic motor, you need a control valve.
   / Vevor Hydraulic Top Link #9
Mine hasn't been worked hard yet.
Just installed it.
Haven't used it enough to know if it needs restrictors for the flow yet.
It's hooked into one of the rear remotes.
   / Vevor Hydraulic Top Link #10
No issues so far.
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
Toro Mower (A50324)
Toro Mower (A50324)
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
LMC LOT NUMBER 143 (A53084)
LMC LOT NUMBER 143...
