Very HOT Hydraulic fluid
   / Very HOT Hydraulic fluid #1
sourmash2
Souheast Alabama
Yanmar 2420D
Hello all, I am a proud owner of a YM2420D which has recently developed a hydraulic problem.
Here is the history; while changing an implement the tractor was started with one of the quick disconnects not entirely seated. It sheared the key on the pump. This was replaced, the system bled, and all seemed fine, but after about 2 hours of moderate work with the FEL, the tractor developed a chatter in the lines and the fluid is getting extremely hot.
I am in the process of draining the system and checking the filter and screen, but any help or suggestions would be greatly appreciated.
Thanks in advance, Scott
P.S. I did a quick search of previous posts, but did not see anything addressing why the fluid would get so hot.
   / Very HOT Hydraulic fluid #2
<font color=blue>...It sheared the key on the pump...</font color=blue>
How about a bad pump...? /w3tcompact/icons/sad.gif (or severe line restriction and running semi-dry)
Perhaps, the pump originally almost seized (running dry or low on fluid), but didn't, sheared the key... ran again for a couple hours when you changed things (fluid etc.) but maybe the damage is already done...?
   / Very HOT Hydraulic fluid #3
I agree with John, it is likely that the pump is damaged. You can take it apart and look, and you will probably find a lot of scoring. I broke a pump once doing something similar. The key and keyway act as a "fuse" that is adequate to keep the pump from exploding, but not always adequate to keep it from harm.
Some of the F-series pumps do not have keys, instead they have a necked down portion of the shaft that acts like a fuse.
   / Very HOT Hydraulic fluid #4
Do you have a lever that is stuck or pulled too far one way and causing the hydraulics to over work it self?
I had that happen on my JD 4400 loader (4 in 1)the lever that was mounted on my fender which opened and closed the 4 in 1 lever was pulled back too far and causing the hydraulics to overwork and heated up the whole sytem,it took me a while to realize what was wrong.
As a matter of fact, that was part of the problem. After doing more reading in the shop manual, I saw a proceedure for heating the hydraulic oil to perform certain tests. This is accompished by closing the slow return valve and raising the control lever to the up position, both were happening to a degree on my tractor (return valve closed 3/4, control lever up 3/4)
Long story short, I put it back together, filled with new fluid, set controls properly, and all seems to be working fine.
Thanks for the help, Scott
   / Very HOT Hydraulic fluid #6
You are more than welcome./w3tcompact/icons/smile.gif
Husqvarna YTH18542 42in Riding Mower (A51694)
Husqvarna YTH18542...
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
SWINGER 2K LOADER (A52472)
SWINGER 2K LOADER...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
