Very heavy load tiedown example
/ Very heavy load tiedown example #1
bcp
Super Star Member
SW WA
Kubota BX2360
/ Very heavy load tiedown example #2
It'll ride.
/ Very heavy load tiedown example #3
Looks like the tie down points are plates welded / fabbed on site. Notice the plate welded to the bottom of the locomotive. The loops make sense since the binders have grab hooks. Chain was cut from bulk lengths. Otherwise they'd have to install shackles or hooks on every chain end. This way they get two strands too.
/ Very heavy load tiedown example #4
....and a Toyota pickup towed the rail car to the yard :D
Neat thread. I didn't know it was acceptable to loop chains through a clevis like that. Looks like only one link is actually in contact.
/ Very heavy load tiedown example #5
It looks OK BUT if they HUMP that flat car in a rail yard it won't hold!!
I have watched loads come right through the rear doors on semi trailers and containers in Piggy Back Yards as the cars slam together when Humping. (Humping- transfering cars to build a train for a destination)
I have replaced many, MANY rear doors and had to trans-load cargo after said damage.
/ Very heavy load tiedown example #6
That's exactly how I tie down my locomotives.:laughing:
Bob
/ Very heavy load tiedown example #8
Bob
sheesh...my dad woulda done that with a 50' roll of twine and about 50 boy scout knots ;)
/ Very heavy load tiedown example #9
I'm actually surprise they loop them through the shackles like that, surprised is in accordance with standards.. Watching chain failure tests anytime a link is wrapped around something like that, that ends up being the failure point.
/ Very heavy load tiedown example #10
Id rate that wrap as being easier on the chain than the grab hooks on the binders are.
larry
/ Very heavy load tiedown example #11
Most likely that's a high value load and wouldn't be humped or kicked but shoved to rest. I would agree "humping" that would be a bad idea. :thumbsup:
For those who may not know, a railroad "hump" yard has a hill at one end. Cars are uncoupled at the top,then roll down through remote controlled switches to the appropriate yard track. There are car retarders to slow them if they go too fast, but the rolling car may hit a standing car hard enough to shift loads or cause damage.
Bruce
/ Very heavy load tiedown example #13
Notice the chains and binders forming a loop, and redundant tiedowns. I've never seen that on trailered equipment hauling that I can recall, even though there was plenty of chain to do it.
Bruce
Two tension members. ... Doubles the fail force.
larry
/ Very heavy load tiedown example #15
Glad I wasn't the engineer at the front of that train!
LOT LOCATIONS (A59914)
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
Wolverine Quick Attach Dozer Blade (A66285)
Wolverine Quick...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
