Very Bad Mulch Video
   / Very Bad Mulch Video #2
Not being a smart azz but what is wrong with that unit?
   / Very Bad Mulch Video #3
Can you believe the guy is cutting with no cab door, no mask, no goggles, etc.
This guy is itchin to take out an eye.
How is he even breathing in all that dust and debris - seriously.
Was refering not only to safety :rolleyes: but to the quality of the final product, the speed at which it cuts, the way the head seems to always be waiting on recovery etc. A lot of this may be the fault of the carrier and or operator but either way it is a bad way to try a unit IMHO
   / Very Bad Mulch Video #5
I what poison ivy tastes like?:D
   / Very Bad Mulch Video #7
With the hydraulic motor driving the drum directly, it's mounted on the end of the head and takes away probably 12 inches of actual cutting width.
I've also noticed that there are alot of YouTube videos for Gehl skidsteers. Why is that? They all seem to be European too.
   / Very Bad Mulch Video #8
the unit is a "tushhog" formerly called a landtamer. I ran one for 2.5 years. The units do leave a "mess" of shreds but they are unstoppable. It is absolutely insane, however, to run one without lexan.
I can say this about the tushhog that is branded under several names. You can mill rocks with it and use it as a crusher on oversized rock to make gravel. You can grind hard, old oak stumps with concrete and metal in them. You can grind a car, too, but that's another story. The first pass with one of these mowers looks like h*ll. I got rid of mine because dealer wouldn't support the unit anymore but it is low maintenance, teeth are reasonable (but hard to install), and it is a powerful, simple piece of machinery. You can grind things that nobody else would attempt. I found it's best use for obliterating stumps and large brush piles with stumps and rocks (see pics)
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
