Vertical exhaust
   / Vertical exhaust #1
pilot-werx
Southern Maine
Does anybody know where a vertical exhaust for a 4210 can be found? Does anyone make them?
Thanks,
Chris
   / Vertical exhaust #2
The current JD 3000-4000 machines have a circular cut-out on the underside of the hood (maybe the 2000 series, too).
Owner's have the option of buying the exhaust pipe and the edging material (cover the hole) for their dealer and installing the vertical exhaust themselves.
Does the hood on your 4210 have the hole-thru option? If not, you may need to install a side-panel exhaust pipe. Similar to the type on the older 50 and 70 JD CUT's.
Give your dealer a call and see what they recommend.
AKfish
   / Vertical exhaust #3
Ditto on giving your dealer a call.
Check out JDparts, it shows a vertical.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
