Vertical Exhaust Kit Install on 3x20??
   / Vertical Exhaust Kit Install on 3x20?? #1
John in the UP
Michigan's Upper Peninsula
2021 John Deere 4066R Snow Cab
I ordered the vertical exhaust kit for my 3320, which I will pick up and install on the tractor this weekend.
My question is this: Does anyone have a pdf file of the installation instructions for the vertical exhaust kit? Or, can someone tell me the correct size of the hole saw required for the cut-out in the hood?
My tractor is 300 miles away, and I want to make sure I have the correct size with me.
Thanks,
-John
   / Vertical Exhaust Kit Install on 3x20?? #2
I put one on my 4105 it tell in the instructions .I went to harbor fright got ten piece large hole saw kit for under ten bucks good for one hole.
My tractor had it already marked were to drill on hood
   / Vertical Exhaust Kit Install on 3x20?? #3
There is a circle on the underside of the hood, that says drill hole here, and there is a circle to give you the right diameter.
   / Vertical Exhaust Kit Install on 3x20?? #4
Yea one says 3x and the other says 4x
The instructions told me to drill the 3x
I will measure the hole when I get to farm tonight
You are going to like it you don't get near the exhaust in your face
Heres a pic you can kind see the stack
   / Vertical Exhaust Kit Install on 3x20?? #5
The hole size I drilled was 3 1/2
Hope this helps
Have fun
Great, thanks for the info - I've got a 3-1/2 in my collection.
-John
2018 Gatormade 20+5 Gooseneck Trailer (A55301)
2018 Gatormade...
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
