Vermeer Stump Grinder
   / Vermeer Stump Grinder #1
Blaneypark
Charlevoix Mi
JD 790, JD4100,JD318,JD216 Grasshopper 322D,Wright 52 Stander
I have a Vermeer 222 Stump grinder. Has anyone had any success in sharpening the carbide teeth on one. I have tried a "green wheel" with no luck. Any ideas out there?
   / Vermeer Stump Grinder #2
How are you holding the tooth and what type of grinder? Sharpening carbide would require either the "Green Wheel" or a diamond wheel. The green wheel will wear a lot in the process. I would recommend the diamond wheel and a method to hold the tooth and control the amount each pass takes off. It will not sharpen fast.
I have not sharpened any of the teeth but I have sharpened lathe tooling. All carbides grind similar but there are many different grades of carbide.
Russell
I tried to use a 4" grinder but had no control. Made a jig to sit on a drill press table and moved the jig back and forth. Had control but a very very slow process.
   / Vermeer Stump Grinder #4
Without tooling to hold and control the cut, it might be better to take it to a shop that can do the job. If you do it yourself, wear a dust mask. The carbide dust is bad for your lungs.
   / Vermeer Stump Grinder #5
I just get them retipped at discount stump cutters .com or something like that. I tried sharpening one once and after a few min all I did was polish it.
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
Deere 9965 Cotton Picker (A53472)
Deere 9965 Cotton...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
