Ventrec PTO
/ Ventrec PTO #11
Got a diesel Ventrac and after it's been running an hour or so the PTO won't kick on without some rocking
Back and forth. Any ideas on where I should look first ?
Just wanted to post in case anybody else has this issue.
The friction plates in the electric clutch can wear. Procedure is to adjust the 3 spring-loaded nuts around the clutch unit. Use a .020" feeler gauge through the access holes in the side of the clutch.
See page 39-40: ogura-clutch.com/files/pdfIMP/PTOinstallation.pdf
/ Ventrec PTO #12
I checked and adjusted mine at 200 hours. It was a bit tight and set a little out of kilter, that is the three check points were a bit different. I set all to spec. Tip, set the largest of the three first, then the next to largest and then the last. The last one may end up a bit snug before adjusting. When finished, all three check spots should match. I had to remove the hood/front grill assembly to access the check windows.
prs
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A60352)
2019 Allmand...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A59230)
2016 Ram 4500 Crew...
Zero Turn Mower (A59231)
Zero Turn Mower...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
