Ventrac 3 Point Hitch Parts
   / Ventrac 3 Point Hitch Parts #1
aadventrac
Ventrac 4231 VXD
Hello to one and all,
I recently purchased a Ventrac 4231. I want to get the 3 point hitch working, however the dealer could not find the parts. Does anyone know if there are parts from other tractor manufacturers that are compatible or can I get universal 3 point hitch parts from my local farm store?
If the farm store route is possible what sizes of the parts should I get?
Let me know when you can.
Thanks and Regards
   / Ventrac 3 Point Hitch Parts #2
I'm a little confused, was this unit built with the 3 point but some of the parts are missing now or it never had a 3 point hitch and you are trying to install one now?
If the unit never had a 3 point hitch, it will be challenging to install even with the genuine Ventrac parts.
But if you just need a top link or draw bar, then the farm store should be fine.
Thanks for your prompt reply. The 3-point hitch mechanism is there just the parts are not. I will try and send pictures.
Regards.
   / Ventrac 3 Point Hitch Parts #4
Your pictures help!
I have the 4500p but it looks like they are very similar.
   / Ventrac 3 Point Hitch Parts #5
They do or did make two different three point hitches... they do list two when I put mine on..... jim
Hello Guys,
Thank you for your replies so far.
Do you think the 3 point hitch kit for a JD1020 series or Kubota B series would work?
   / Ventrac 3 Point Hitch Parts #7
I looked on Amazon to see these parts and as they ship - no I don't think they will fit.
Can you make them fit - I don't know. Seems like you would definitely additional hardware.
I see a couple problems and there may be more but this is what I see:
In the picture I've attached, you can see how the Ventrac lower arm stabilizer attaches directly to the bolt that holds the lower arm to the tractor. The Kubota B series connects to a different place - a plate is pinned to this bolt. It is also on the inside of the arms and the Ventrac is on the outside. I think the stabilizers are a different hole size as well.
On the Ventrac, two bolts hold on the two lower arms and the Kubota just has one pin.
I don't see any specs on the length of the arms either.
Have you tried calling your Ventrac rep to see if you can purchase these missing pieces? I would recommend exploring this before buying any 3rd party kit.
   / Ventrac 3 Point Hitch Parts #8
I do have the manual top link, I use the hydraulic. one... I would check with Ventrac on the other four parts you need ... The arms and links are made for the Ventrac.... jim
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2019 Ford F-150 Ext. Cab Pickup Truck (A55788)
2019 Ford F-150...
2014 MACK CHU613 DAYCAB (A55745)
2014 MACK CHU613...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
