Ventless Gas Heater - Smell
/ Ventless Gas Heater - Smell #1
Dougd
Southern Indiana
Just installed a propane 30K BTU ventless gas heater on my enclosed-but-far-from-airtight porch; produces great heat but there's a smell that my family finds quite obnoxious. The flame pattern is by-the-book blue, the paint/oiled surfaces that were going to burn have been burnt , the smell is apparently some by-product of combustion, but what? I'm of the opinion it's the combustion of the mercaptan that's added to LP to make it smell, but have found no references to that possibility in hours of internet searching.
No CO2 or CO problems.
Happens as soon as we fire the thing up, it's not an oxygen-shortage issue.
Have not had the LP pressure tested at the heater, but it's the same line that feeds my furnace and cook-top and both are operating fine. Heater is dual-fuel, curently running on LP.
The cook-top is a 4-burner unvented unit and we don't notice the same smell when cooking even with 3 burners going at the same time.
Any ideas?
/ Ventless Gas Heater - Smell #2
I think you are going to have some smell with the ventless LP heaters. We have a ventless fireplace and it produces a smell as well. Usually when I enter someone's house I can tell if they are using LP gas for heat. I don't think it is anything to worry about, but sometimes the smell can be a nuisance. Currently, we only use our fireplace as supplemental heat due to the smell. Even the pilot light produces a little smell. When I walk into the house after work, I can immediately tell if the fireplace has been on that day by the smell.
/ Ventless Gas Heater - Smell #3
Well while we are on the vent less heaters I got a question.
I with a friend to his cabin last weekend he has one for heat.
The neighbor turned it on before we got there so the place was warmed up for us.
All the surfaces had condensation on them the temp was in the low 20's so the place was really cold.
It did dry off through the night but it seemed unusual to me.
The reason I ask is I bought one to put in my cabin so I don't have to get up in the night if the wood stove go's out.
I just haven't got around to hooking it up yet and if it puts that much moisture in the air I might have one for sale!
I didn't notice any odd smells though.
tom
/ Ventless Gas Heater - Smell #5
We have been using a ventless space heater for several years in the back of the house where heat from the wood stove has a hard time getting into. NO odor, CO or fumes of any kind. The only problem has been that I finally had to get some bottled air in a small can and blow out the pilot tube.
Could not be happier with a supplimental heat sourse. Sure beats running the heat pumps..........Dennis
/ Ventless Gas Heater - Smell #6
I've also been looking into them, and did read there may be condensation. As far as the smell I haven't read anything on that but I quess it could be possible?
/ Ventless Gas Heater - Smell #7
If it's a "blue flame" heater they give off a good bit of smell. So much that I gave the one that I had bought to an aunt and replaced it with a 3 brick radiant heater.
The gas logs that we put in our house also give off a good bit of smell. They are "vent free". We only use them during a power outage though.
Chris
/ Ventless Gas Heater - Smell #8
/ Ventless Gas Heater - Smell #9
I'VE READ ONLINE ABOUT THE SMELL BUT DONT KNOW IF IT HAPPENS WITH NATURAL GAS. I WAS PLANNING ON BUYING ONE BUT STILL RESEARCHING. I HAVE A WARM MORNING GAS HEATER (BY LOCKE STOVE CO. ITS NO LONGER IN BUSINESS) WOULD APPRECIATE IT IF SOMEONE OUT THERE HAS INFO ABOUT IT. IT WORKS FINE BUT PILOT SOMETIMES GOES OUT, I DONT KNOW WHY.
/ Ventless Gas Heater - Smell #11
If listed. These heaters have been tested & approved by the AGA( American Gas Association) similar to UL . They are also approved by the IFGC as a back up heat source only. Some states/ cities may not allow them for use at all. I've been in the business for 25 yrs & have installed many of these heaters with ODS pilot. Haven't had any of my customers die from 1 yet From time to time the odor may be stronger than others. Never can tell when someone will add too much odorant to the gas
/ Ventless Gas Heater - Smell #12
Been piddling in HVAC field for the last 17 years.
I needed to replace my first floor system and couldn't justify the money for a two stage variable speed 95% gas furnace for back up heat only on the first floor (and that was at my cost). Also couldn't justify the cost of a wood fireplace insert for back up heat. Went with a 14 SEER variable speed heat pump and used a vent free fireplace insert and absolutely love it with no problems. Best bang for the buck money I spent for heating. I have another system upstairs and another one downstairs, and both ECM fans move the warm air from the vent free fireplace very well. Run the gas logs for a couple of hours in the morning to bring up the heat, then let the heat pumps take over. Usually use the fireplace for no more than three months out of the year. Again, no complaints.
Forgot to mention, that ventless heater was the first one I ever put in because I really never thought that highly of them in the past. Figure there is no better advertisment than having something in your own home. I now have no qualms reccomending one.
Also knew of a licenced plumber who installed a water heater in his own home and killed himself due to the venting. Point being there are many small things that can get you.
I've got six various gas dectectors in the house.
Depending on how much you're paying for electric, the heat pumps could be much cheaper to run (less electric strip heat). Complaint on heat pumps from people use to gas or oil is the air discharge temp from the registers. On average, with a properly installed duct system with R22, your discharge temp will be under 98 degrees, less than your body temp, so the air actually feels "cool" even though you can/could maintain 72 degrees no problem.
However, with a proper ducted system using R410A, your average discharge temps will run over 98.6 degrees (warmer than your body temp) thus the air will feel warmer coming out of the registers.
General rule of thumb out in the field dealing with homeowners is that if the customer is over 60 years old and has an oil furance or gas furance, worst case is duel fuel the system (running gas/oil with heat pump) but do not put in a heat pump only because you WILL get a call to come back out telling you that the system is not heating properly even though the t-stat is set for 74 and guess what, using three different thermometers, it is actually 74 degrees in the house, but it still feels "cold":rolleyes:
/ Ventless Gas Heater - Smell #13
I've had ventless propane logs for nine years now. They are the largest logs that can be legally be sold and I use them every night for ambiance and heat. There is no odor, condensation or carbon monoxide problems. And I've never had visitors comment on the smell. I don't understand why you guys have had problems. I think that you need to have a technician look into your problems.
Every so often, like once a season, the pilot light fails. A smoking-pipe cleaner, two feet of tubing and my breath cleans out the pilot assembly.
I often have a problem with the flame roaring (sound) due to ordinary air in the pipes. So I turn off the flame and a second later relight it. That always works.
Yes, it's a blue flame, Pro-Com is the name on the heater. It pretty much makes the space nice and warm but unusable due to the smell. My furnace has a plastic "flue" that exhausts outside the house, the exhaust of the furnace smells the same as the heater, but not as strong.
I'm going to try one of the catalytic heaters, just for comparison sake.
This kinda sucks, that was a $400 heater all-told and I had such high hopes.
/ Ventless Gas Heater - Smell #15
if you have a neighbor or friend in your area that uses a different propane company. Try the heater at his place & see if you still get the strong odor. Like I stated, sometimes they add a little too much odorant by mistake. Once added they can't remove it
/ Ventless Gas Heater - Smell #17
tom
I put a ventless gaslog set in the gameroom of my mom's house...they kick out a ton of humidity ..in fact, the drop ceiling rails started started to get suface rust on them...They were brand new:mad:
It does thow a lot of heat however.
Combine that with 20 degree temps, and you're going to get a lot of condensation, at least until the place is completly warmed up..Direct vent is the way to go.
/ Ventless Gas Heater - Smell #18
Sometimes off spec propane will get into the market place as the suppliers are dead ended with it. The H2S makes for a nice smell. Mercaptan also has sulfur elements in it. :D
When the heaters are tested for emissions pure propane will most likely be used. This burns with by products of water and carbon dioxide. In the real world propane may contain various impurities that may affect what by products are present.:D
These impurities will vary as to the source of condensate from which propane is fractionated and they may not all be removed.:D
There are spec's that propane has to meet to be saleable but there are many times off spec product is blended with on spec. to make a saleable product. And at times an off spec product gets through and is delivered to the consumer.:D
/ Ventless Gas Heater - Smell #19
I'd suspect the gas supplier, and additives. Talk to them, and see what they have to say.
I had one in my garage, but finally quit using it and removed it. The moisture from the gas combustion just was causing too much problem. Bringing in cars that were wet from snow and roads didn't help any either, but better off without heat than have everything dripping wet.
/ Ventless Gas Heater - Smell #20
it's been my experience that ventless lp heaters stink,at least with the local lp suppliers around here, i would rather use a kerosene heater, they stink too, but not as bad.
2022 CHEVROLET EQUINOX SUV (A66091)
2022 CHEVROLET...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
PORTA POTTY (A68842)
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
