VEMEER 505G
/ VEMEER 505G
If you are going to re-lace the ends make sure to cut them equal lengths and that the ends are cut square. Other wise the bales will be fluffy (loose) on one side, tight on the other and the belts will track crooked and try to flip over.
I intend to all tho it would shorten to maybe an inch under the 336" the manual suggested cut. The 10" I'll have to bring somewhere to get laced, which need it bad. I have a 6" but no 10" tool as of yet.
/ VEMEER 505G #22
I would have thought Vermeer would have had a more "sophisticated way" to remove tension on the belts than a log chain. I'm glad I own a JD rd baler.
When Vermeer made this G round baler JD did not have an open throat baler. JD was in the dark ages with the 410 & 510 round balers. The JD 430 & 530 were introduced in 1986-87. Of which JD lost a patent infringement law suit on Hesston's patents.
/ VEMEER 505G #23
So are you stating because of JD's patent infringement Vermeer decided to utilize a log chain to relieve tension on belts when repairs were required?? JD still utilizes the same type tension roller arrangement(patent infringement) on the new balers built today that the 430//530's utilized.
/ VEMEER 505G
So HayDR, your saying JD stole the open throat from Hesston?
No,no, Tx Jim. What he's saying is Vermeer has little reason to add the expense of releasing belt tension, because they have so little belt problems, they decided to pass the savings along to the customer. Well it sounds good anyhow. Their both good balers
/ VEMEER 505G #25
Hesston's suit had to do with the tension rollers & arm inside the baler not the open throat design. As I previously stated JD rd balers built today still utilize the same type tension rollers/arm!!!!!!! I agree that both brands are good balers. For some reason I see very few Vermeer rd balers baling hay down here where I live. I own a Vermeer 7030 disc cutter and I like the quick change blade feature.
/ VEMEER 505G
One reason I went with vermeer, is the vermeer dealer altho 30-40 miles further. The vermeer people are alot friendlier than the JD. I like a dealer that is friendly to all, not just the mega farmers with 20 to 40 tractors. Could be the reason their always changing names, but not faces. Which I see as the problem.
/ VEMEER 505G #27
Andy
I totally agree. My brother who had been a JD dealer from '53 to '88 sold out to larger conglomerate. A few yrs later my ex-SIL(brothers ex) was invited to sell out her dealership (acquired from divorce from my brother)to a larger conglomerate which was the same conglomerate that purchased my brothers dealership. IMHO JD company isn't the same friendly/helpful company especially for a small farmer as it was in the earlier years.
/ VEMEER 505G #28
I fail to see how my Kubota tractor enters into this thread. BTW you left out the Ford tractor,H&S rake & Vermeer disc cutter that I own. Sorry if I got your knickers wadded but I would have thought as long as Vermeer has been producing Rd balers they would have come up with a better way to remove tension from the belts besides a "LOG CHAIN". Granted a 504G isn't a newer model but even on JD's early model rd baler built back over 30 yrs ago all one had to do to relieve pressure on belts was insert 2 pins that were provided with baler. Granted the JD baler I mentioned (410/510) was not a very good rd baler model either!!!!!! Have a nice day,Jim
That JD Baler you have is about the only thing they make anymore worth having, lol, They still have good balers. He can buy a set of belts for that vermeer though for about 600 dollars, Versus 3000 dollars for the Deere. Im glad this post was here though because I had a 504C given to me the other day. Now I know how to change belts. These are some old balers man.
/ VEMEER 505G #29
Most of the people I make hay for prefer smaller bales, and it less trouble shipping outta state. I've been hauling hay through Baton Rouge and I wouldn't wanna have to go through the streets of LSU with 5' bales. And the trucking companys want more money for the big bales. They want a little more for 4x6
verses 4x5. Now I have variety.
I like the smaller bales also, and a lot of folks are going to compact tractors so the small bales are handy here, And if the hay is top quality Ive found that it brings more money, The big money nowdays is going back to small square bales Ive also noticed.
/ VEMEER 505G #30
IMHO JD isn't the same company nor does it build the same quality equipment as it did years ago. But I'll match my JD 467 up against any other rd baler models.
/ VEMEER 505G #31
Andy
Thats for sure, Sometimes The ones in Durant Oklahoma act like politicians or something, Like they want to treat you like a peasant . Even though they are the ones punching a time clock and working for the man.
/ VEMEER 505G #33
Down here JD rd balers do over 90% of the baling
/ VEMEER 505G #34
I need to talk to one of you Men about choosing a roller pump. The one I bought may be too big for the job. What Im wanting to do is spray pastures , I bought the 6900 series delavan 8 roller 23 gallon a minute , and bought 2 nozzels and a 260 gallon tank . The nozzels are 1/2 inch and with #10 orfice . is this too much pump?
/ VEMEER 505G
Nozzles have a mim and max psi. The Regulating Bypass Valve, regulates the psi. When you have it set for the gals of water per acre the extra flow will bypass and go beck into the tank. I'm not sure how those wide band nozzles work, but it seems you'd need the same flow as 18" nozzles spaces on a 20 to 30 foot boom, if not more flow.
/ VEMEER 505G
That's a good price on the 504C. I'll take a 1/2 doz or so at that price. All tho I do believe that baler is closed throat
/ VEMEER 505G #37
Yes its closed throat, The Old guy said the hay has to be dry, Absolutely has to be dry. Or you will be fighting it all day. But Im just starting out and I didnt want to be going and getting my dads baler all the time. And like you said at that price Lol I cant go wrong. He said as long as the hay is dry it will gobbel up anything I can drag it over though. But Im worried Ill be fighting it all summer. I will have a few people standing buy just in case it does not work, They will jump at the opprtunity just to come help bale for a cut. Its ryegrass mixed with vetch and yellow hop, and I fertilized it with ag lime and 17-6-6. No weeds at all. It would make horse hay.
/ VEMEER 505G
Is there any problem with running belts 2 inches shorter than vermeer recommends. What would the out come be. ie tighter bales, strain on baler, no difference. Your thoughts please. (504G)
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
213121 (A64276)
213121 (A64276)
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
