Various Tractor Fluids, YM2000 w/Loader
   / Various Tractor Fluids, YM2000 w/Loader #1
jfobel
Hi Folks,
I received a hard copy of my service manual the other day. Too bad I was expecting a nicely laminited edition. I think I should have orderd the CD instead, lol.
Anyhow, I could not locate anywhere within the manual where to check the hydraulic fluid for either the 3pt lift nor the front loader. So far I have located the engine, transmission and coolant -but none of the hydraulics.
Can anyone help me locate the where to check hydraulic fluids?
Am i missing any other fluids?
Almost forgot, here are some pics of my new toy. Thanks again for ya'lls help.
Jack
   / Various Tractor Fluids, YM2000 w/Loader #2
It should be around the top of the transmission around the shifter area
That is the transmission.
   / Various Tractor Fluids, YM2000 w/Loader #4
The transmission & hydraulic system use the same reservoir. That info will not be in the service manual. It is in the operation manual..
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / Various Tractor Fluids, YM2000 w/Loader #5
The transmission & hyd fluid are one in the same. Use JD 303 spec. fluid
Interesting... I am new to tractors so everything is a surprise to me, lol. Sounds very low maintenance. So both the 3pt lift and front loader operate from the same fluids?
   / Various Tractor Fluids, YM2000 w/Loader #7
Yep & transmission
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
