Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,072
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My Brother in law & wife are visiting. they have a van, unsure of make/model/year (and don't think that might really matter)
None the less, the van overheats & here's the symptoms
1. Sitting at idle, temp will be fine
2. Driving temp will get to hot range, turning heater on will QUICKLY drop the temp, evidently even while driving (fun in June huh? /forums/images/graemlins/shocked.gif)
I figure it's one of two things, radiator core or thermostat
My first line of guess is thermostat because at idle it won't overheat (slight water passage, low load). I think that if driving under load and turning the heater on would be sucking heat out of the engine (on the "inside loop" of the thermostat)
Then again, we had engine hot, (opened the radiator cap BEFORE hand) and the water was flowing NICELY in there, indicating thermostat is working fine. Also, there were intermittent bubbles popping out of the (removed) cap.
Every now & then, the water would "roil" out of the (removed) cap as though it was under some other kind of pressure. It would be all frothy, bubbly...and then seem to calm down to the traditional movement I'd otherwise expect from a properly working radiator.
So, that's the gist of what I saw. My first guess is sticking cap. The bad part is, this is one of those engines that are simply a PAIN in the hiney to get to, to work on /forums/images/graemlins/mad.gif
Any guesses as to which one is culpret?
There will be a prize for the lucky winner... perhaps a wapper off a pre-tested (eaten) hershey almond nugget? /forums/images/graemlins/shocked.gif
/forums/images/graemlins/grin.gif
Oh, I forgot to mention... I asked if radiator ever runs low (sucking water into heads, or dripping out of pump). I'm assured that it loses zero water. I'm taking that at face value.
