bindian
Super Member
I won the bid on Big Iron for 4 new 16.9x28 tires from Mahindra with the rims. All 4 tires are mounted all the same direction. So I thought I could mount one as is and have the tire shop swap one. I will resale the other two.
The wheel and hub are not at my tractor's settings, so today I took one in the barn and blocked it up and swapped the hub 180 degrees. But it seems the valve stem will be on the inside. These rims match my rim part number. But mine were made in 2005 and these rims were made in 2018.
Has Mahindra started putting valve stems inside on their 50-70 hp rear rims? This is the only way the spacing will match mine on my 6520.
hugs, Brandi
hugs, Brandi
