Valve stem will not let air out?
   / Valve stem will not let air out? #1
DutchHenryBrown
Platinum Member
Tombstone, AT
Mahindra 5010
I wanted to let some air out of my rear tires which have a stop leak in them from the dealer, not sure what kind. Checked air pressure first and nothing pressed the valve nothing? I'm guessing that the stop leak stuff has screwed up the valve so I'm thinking unscrew the valve and real quick put in a new one or suggestions? :confused:
   / Valve stem will not let air out? #2
I agree, Remove the valve core and replace it. Once removed you may have to stick a piece of wire through the hole to clear the stop leak. Seems like the stop leak has sealed over the fill port.
   / Valve stem will not let air out? #3
just blow some air into it to clear the valve. 90% of the time that fill fix it. if not, jack that side up, then remove the core carefully, and then poke something int here to make sur ethe stem is not loaded full, then replace the core.
post back
Thanks George, both you and Soundguy came up with the way to clear it.
post back
Thanks Soundguy, never crossed my mind to hit it with some air first before pulling the core? :duh:
   / Valve stem will not let air out? #6
It is always good to inflate a bit first so your pressure gauge does not get filled with crud. I keep forgetting for some reason.
   / Valve stem will not let air out? #7
so you got it now? valve working ( repalced or celaned? )
Been a while old computer gave up the ghost had to end up buying a new one!!
Soundguy, like you said hitting valve stem with air cleared it right up, thanks for the heads up.
   / Valve stem will not let air out? #9
glad to help!
2013 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2013 FREIGHTLINER...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
