Valve questions
   / Valve questions #1
Rio_Grande
Platinum Member
I posted earlier this year about this valve I bought.
I finnaly got some litterature about the valve but still have some questions. Can you fellas look over this and tell me what I have. Then I will likely have a few more questions.
The PDF file should be attached.
  • V10 Sales[1].pdf
   / Valve questions #2
Couldn't open your pdf. I think I remember-some kind of ebay deal? nice looking valve. I got a Hussco 5000-C series(off junk fork lift) triple stack 2 double acting&1 single acting(I think? I hope) I got same questions about my valve too. But I'm too stupid to post pics:D Going to take mine(when I get a round-tuit) to local mach/hyd shop w/questions and get a few fittings & maybe hoses. theyr'e a little high$ but they forgot more than I will ever know about hyd stuff. countryside hyd shop is invaluble in my opinion.:) GOOD LUCK
   / Valve questions #3
The link works for me. I went to the chapter on "work sections". That is where you need to go to determine what you have.
Without more information on the physical thing you got, more detail is not possible. Sorry, but there are just too many options possible!
jb
   / Valve questions #4
jb
John_bud, If thats the case, then Rio should get his answers in that chapter and maybe repost his actual valve pics. I wasn't as lucky or smart enough finding pdf w/work sections on my Husco 5000-c valve. was made in England?/not made anymore/proprietory info/special made (I guess for forklift mfg.?) yada yada.:)
   / Valve questions
Thanks fellas, I am going to take it into the hyd shop next time I go, I just don't have time to try and figure it out.
   / Valve questions #6
A lot of Husco stuff is made for equipment manufacturers. Husco won't sell anything for it, you have to go thru the equipment manufacturer it was made for. I have gone thru this with Husco valves made for John Deere. Just my opinion now, but I would absolutely never buy a John Deere just because of all the proprietary stuff they have on their hydraulics. A customer of mine brought in a Husco valve last week from a JD bulldozer. Spools were sticking. He wanted a new valve. Husco told me to pound salt and go thru JD. (Not in those words) The new valve from JD was $600 per spool, there were 3 spools, do the math. I could get a valve that was close, but not close enough to work, for $200. For the whole valve!
   / Valve questions #7
There should be a tag on the valve with #'s. E-mail Parker with this info, they will tell you exactly what you have. Looking at the catalog you attached, there are way too many options to determine anything. To give an example, looking at your attachment is the equivalent of looking at a brochure for 2008 Chevy trucks and trying to figure out what options your truck has without being able to see it.
   / Valve questions #8
They do the same with Kubota, many here over the years has tried to get stuff from Husco for thier Kubs and no dice:mad:
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
