Paddy
Veteran Member
Ok, I have fanally started the valve adj and head bolt torquing. Torquing went well. I pulled each one at a time a lubed and installed. On to valve adj. I did as instructed and as soon as the #1 intake closed should be TDC, sure enough, the fly wheel has a mark stamped 1 right a tick mark on the bell housing! After I adj the valves in this position, I need to move 240 deg to find TDC for cyc number 3. Finding 240 degs will be more tricky than just doing the same thing for cyc number 3, just as the intack closes. Could be moot point if the fly wheel is stamped!
Another thought. I think I read if you adj in the small end of the lash range, .25 mm of the .25 to .35mm range, they will wear in to the middle? sound right?
What cha think?
What cha think?
