Valve inaccessible. Slipped tube?
   / Valve inaccessible. Slipped tube?
I forgot to say that I let all the air out before prying the valve back into position.
   / Valve inaccessible. Slipped tube? #22
I'm glad you got it fixed.
   / Valve inaccessible. Slipped tube? #23
Good job!
Glad it worked out for you.
   / Valve inaccessible. Slipped tube? #24
As many indicated, this was in part caused by the ballast in the tube, but also in part due to low air pressure. It has been almost 2 months since your post that you got ur valve stem in a better position.
I suggest that you set a schedule perhaps the 1st of each month to check your tire pressure. That should be much more often than you need to add air, but it would only take a few minutes to check all 4 tires.
Congrats on getting it realigned!
   / Valve inaccessible. Slipped tube? #25
When this happens on a dirtbike the only thing we can do is puncture the tube to deflate. Then new tube or patch, remount the tire.
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
1992 GMC C7000 Topkick Dump Truck, VIN # 1GDM7H1J9NJ522223 (A57453)
1992 GMC C7000...
Massey Ferguson 1759 (A57148)
Massey Ferguson...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
1000 Gallon Fuel Tank (A57149)
1000 Gallon Fuel...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
