Valve Guides on L185 Kabota
   / Valve Guides on L185 Kabota #1
L1500123012
Springhill Fl.
zen-noh 1501
Can anyone tell me how diffacult it is to replace valve seals and guides on a L185 kabota 2 cyl. diesel? what special tools do i need. valve spring compressor Im sure, anything else?? Thanks
   / Valve Guides on L185 Kabota #2
if you want to change the Guides, you'll have to bring them to a machinist / dealer. If you want to change the valve seals, you should be fine doing it yourself and you can do it with a leakdown tester and do this without having to remove the head. at least, if you can do it like on a car (i don't know Kubota's engine...)
hope you the best
   / Valve Guides on L185 Kabota #3
Generally speaking you need a special tool to drive the guides out and a press and tool to press the new ones in. Or a special tool and press to press the old ones out and the new ones in.
Thanks for the info. I getting ready to start tear down and waiting for a service manuel I hopefully will only need new valve seals. again thenks for the replys.
   / Valve Guides on L185 Kabota #5
Are you certain that your guides are bad. Have you measured the valve stems for wear? How many hours are on the engine?
No Im not certain of anything yet, except that it smokes alot it could just be rings are bad. I just purchased the tractor used and the hr meter does not work so I dont know how many hrs.I will know more once I start taking it apart.
Genie GTH-844 (A50120)
(2) ROCK GUARDS FOR 2022 FORD BRONCO (A51244)
(2) ROCK GUARDS...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
Truck Bed (A50774)
Truck Bed (A50774)
2018 FORD F550 XL SINGLE CAB SERVICE TRUCK (A51243)
2018 FORD F550 XL...
