J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
On the one J_J refers too , YES, on the one I show, NO, and they are two different Prince valves....I noticed this "discrepancy" a while ago.....no biggie....but a little disturbing....because it is inconsistant....I think that it is, sort of, common custom in valve industry, to have B port plugged, if it is a Way valve for a single acting cylinder....
WOOOPPS my bad...to tired.....sorry....A port of course plugged on my picture too...
In the PDF above, Prince says if using the valve as a three way, to plug A port and connect cyl to B
The reason for the question, was that in using a double acting valve with a SA cyl, I would think the valve ports would have same characteristics, and therefore, either port could be plugged, depending on the way you wanted the lever to operate the cyl.
I will call Prince Mon to find out for sure.
dcyrilc,
I think you have to plug the other port in case someone inadvertently shifts the lever the wrong way.
