valve availability?
/ valve availability? #21
Look on the Ytmag parts site, they have good descriptions for the correct plate for your machine. Hard for me to look on my phone.
Oh and you are correct on your flow rate. I was just in another post with a hundred series and still thinking about those pumps.. You are still fine with an 8gpm valve
No worries on the flow rate, I know you're all over the board, hard to keep track, I knew my pump size, it just didn't click until it was too late lol. Looks like either plate would work. The one with 3 ports looks like it has doubled in price over the last 10 years. Has p,r, and pb port. I assume that with that valve I looked at it just needs hooked up with the corresponding ports? If I got the the two port adapter, then pressure would go to inlet of valve, pb on valve would go to return port to run the 3 pt, and I would have to drop the return from the valve to the sump somewhere (fill plug tap or similar)? Sound correct, thanks a lot for your ongoing help with this. I really appreciate it.
/ valve availability? #23
As long as you are oc, and oil can Flo out of the plate and then be returned with the plate, and the valve outlet can handle downstream pressure you should be good
Just an update. I ended up getting a used original remote block off plate, the two port plate and that valve I posted. P on the plate went to p on the valve, installed high pressure plug in c port of valve to make it power beyond and then plumbed that port back to the remaining port on the aluminum remote block. T from the valve got plumbed into the inspection cover on left side to return back to dump. Everything worked just as it should on the first try.
/ valve availability? #25
good to hear. those adapter plates are way cheaper than oem valves, or the repops.
I didn't really want to give any of the 3 cylinder functions and it looked like most of the oem stuff was for two. Thanks again for your help.
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
John Deere 8370R (A64126)
John Deere 8370R...
213086 (A64276)
213086 (A64276)
