valve adjustment
/ valve adjustment #1
rbushmaster
i have a prince rd 5000 series control valve with a barnes 2 stage 22gpm pump
when i hit 2000 psi it seems to bypass.the splitter cylinder stops and the engine is not bogging even at idle . Im guessing its the relief setting?
instruction that came with valve says nothing about where/how to adjust
/ valve adjustment #2
Mostly close to P port (inlet), some have a bolt (minus the head) like with screw driver slot and a jam nut.
/ valve adjustment #3
You will also need a gauge to set the PRV properly.
/ valve adjustment #4
Valve description
Parts
Plumbing instruction
Reading these pdf files will give you info about the valev in general and even some details about the relief valve adjustment....
Always adjust live under pressure, with a proper gauge (0-3000psi)
Check how pressure react on the screw adjustment, by adjusting "down" first....then up....
/ valve adjustment
thanks again fellas,
now i think i have a problem with the new pump afer splitting 2 cords wood the pump sounds like a jack hammer almost sounds like a engine rod nock but its not the engine.
/ valve adjustment #6
Most splitters have a 2 stage pump. Maybe you adjusted the cross over pressure and not the relief? Did you put a gage on it or just screw it down tight?
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2016 Nissan Versa Sedan (A64557)
2016 Nissan Versa...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
