valve adjustment
   / valve adjustment #1
rbushmaster
i have a prince rd 5000 series control valve with a barnes 2 stage 22gpm pump
when i hit 2000 psi it seems to bypass.the splitter cylinder stops and the engine is not bogging even at idle . Im guessing its the relief setting?
instruction that came with valve says nothing about where/how to adjust
   / valve adjustment #2
Mostly close to P port (inlet), some have a bolt (minus the head) like with screw driver slot and a jam nut.
   / valve adjustment #3
You will also need a gauge to set the PRV properly.
   / valve adjustment #4
Valve description
Parts
Plumbing instruction
Reading these pdf files will give you info about the valev in general and even some details about the relief valve adjustment....
Always adjust live under pressure, with a proper gauge (0-3000psi)
Check how pressure react on the screw adjustment, by adjusting "down" first....then up....
   / valve adjustment
thanks again fellas,
now i think i have a problem with the new pump afer splitting 2 cords wood the pump sounds like a jack hammer almost sounds like a engine rod nock but its not the engine.
   / valve adjustment #6
Most splitters have a 2 stage pump. Maybe you adjusted the cross over pressure and not the relief? Did you put a gage on it or just screw it down tight?
   / valve adjustment
havent even touched the adjustment yet
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
1996 CHEVROLET CAPRICE SEDAN (A52576)
1996 CHEVROLET...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
