valve adj M8540?
/ valve adj M8540? #1
big bubba
Elite Member
arkansas
M8540
ok so i have 770 hrs on my M8540 purchased new. flawless engine, runs quiet & smooth w/o valve lash noise i've encountered on other engines that need valve adjustment, etc.
have done valve adj on engines for most of adult life. but i hesitate to open the valve cover from the factory assembly. the manual does state to adj valves around those hrs. your take & experience on diesels with those hrs? recommendations?
i'll probably do it eventually anyway & get the intake/exhaust clearances from my dealer.... but just to run by the forum thx in advance
/ valve adj M8540? #2
Why would you hesitate? It's gotta be done. While you're ordering a valve cover gasket, order the seals and/or gaskets for the injectors. You'll need to remove those to turn the engine over. Unless you're some kind of Super-Man. :)
/ valve adj M8540? #3
Couple years ago - Kubota service tech came out and installed an upgrade step on my M6040. I asked him about the 800 hour valve adjustment. His reply - if the engine is running OK then do not worry about needing any adjustment. In other words - if it ain't broken, don't try to fix it. Sounds like sound advice to me..........
/ valve adj M8540?
thank you. i'll look into the possibility later on, but it runs like out of the showroom, will hold off for now
/ valve adj M8540? #5
If an exhaust valve's clearance is too tight it'll sound and run fine right up until the valve is burned.
I wonder why CUT makers don't use hydraulic lifters or adjusters? The extra valvetrain weight isn't going to hurt performance on an engine with a 3000 rpm redline.
/ valve adj M8540? #6
Look over the WSM procedure on the attached page.
I too think the Kubota mechanic who said if it is running well leave it alone gave bad advice.
Dave M7040
  • forum M8540 valve adjust.pdf
