Value of a Used Ford 7011-II
   / Value of a Used Ford 7011-II #1
Patternmkr
Anyone know what a Ford/New Holland 7011-II 4 wheel drive is worth? Cab, Heat,Air. No loader. Nice tires, Good original paint, Front weights. Age 1990+
Thanks
Scott
   / Value of a Used Ford 7011-II #2
Do you mean a 7710 II?
   / Value of a Used Ford 7011-II #3
Not a model i've heard of , Check again.7610,7710,7910,7810 but that would be newer ? Check again.
Oops, My typing fingers got ahead of my brain. Yes, It's a 7010-II
   / Value of a Used Ford 7011-II #5
The only NH 7010's I can find on fastline are open stations but the FWA one was $14,900 and the 2wd was around $12k. I have never even seen a 7010 other then in pictures so I can't really tell you what it should be worth. But at least these prices can give you an idea what others are selling for.
   / Value of a Used Ford 7011-II #6
What is this ? an export model or something , i've never heard of it .
   / Value of a Used Ford 7011-II #7
It is a late 90's New Holland tractor that appears to base its existance of the original 7600 line. It looks quite similar to the 7610S and the other S line of New Hollands from the late 90's. Go to fastline and type in 7010 and it will bring up a couple New Hollands so you can see what they look like. They made them from 1995 to 2003 and they were a 86 pto hp tractor much like the 7740 as I think it had the same engine.
   / Value of a Used Ford 7011-II #8
I looked the 7010 up in one of my Ford and New Holland books, it lists a 7010 and 8010 as low profile tractors. Saw one on NH's used tractor listings in California, appears to be an orchard or vineyard tractor, very wide rear fenders covering the width of the rear tires. No idea on value, this one was listed at $14900.
   / Value of a Used Ford 7011-II #9
The 7010 is a low profile tractor but not in the same way as an orchard tractor is. It is more like the 7610 as it is too big for most orchards. If my memory serves me, the 7010 was a price tractor similar to what the TD-D tractor is now in New Hollands lineup.
Case IH 2388 Combine (A50514)
Case IH 2388...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
1997 Semi Dump Trailer (A50514)
1997 Semi Dump...
EZGO (A50324)
EZGO (A50324)
