Value of a Kubota B7300
   / Value of a Kubota B7300 #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
I looked at a B7300 with a 60' MMM tonight. It has about 600 hours on it. I don't know anything about this model, and I'd like to get some opinions of what you guys think it might be worth. FYI, no FEL.
I'm sure I can buy it for $4,000 and maybe less. But I have no idea if that's a decent deal or not. I've been looking at zero turn mowers, but this would fit my needs better and you can't buy any decent ZTR, even used, for $4,000.
It ran fine, everything worked and didn't have any obvious issues EXCEPT for one thing. It leaks oil from somewhere onto the front middle of the MMM. I couldn't identify the source of the leak. There is a rubber boot underneath the tractor that appears to surround a connecting point on the drive shaft to the front wheels. That rubber boot is directly above the front of the MMM, and the rubber boot was somewhat oily, but I think the oil is leaking from somewhere above that boot. It appears to be a very slow leak, as I didn't see it drip while I was there. (You can probably tell I'm not a mechanic. :laughing: )
Worries me a little bit, but I might roll the dice if the price is right. I'm not qualified to split a tractor, so if the issue is a big deal I'd have to take it to the Kubota dealer, which might mean big bucks.
   / Value of a Kubota B7300 #2
4K for a b7300 with 600hrs and mmm is a good deal around here, leaks and all.
It's a good deal around here also. I don't mind spending a little to fix it up, but I'm trying not to buy a money pit.
I was hoping this was a problem somebody on here had seen before and could shed some light on.
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
KUBOTA M7-132 (A53084)
378813 (A51573)
378813 (A51573)
2022 Toro 21in Hydraulic Walk-Behind Turf Aerator (A52377)
2022 Toro 21in...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
UNUSED LANDHONOR LHR-SP100 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
