Value of a dead 240D
   / Value of a dead 240D #1
Trkrd
Arkansas
YM240D
I have an opportunity to pick up a 240D that is not running for $2200. The owner claims it ran fine all summer and after sitting for a few months would not start and had quite a bit of fuel in the oil pan. Other than that seems to be in very good shape (sheet metal, rubber, etc.) Does this seem like a fair price? My intent is to supplement my (now nonexistent) income by getting it healthy and reselling it in a few months.
   / Value of a dead 240D #2
If the seller is telling the truth then $2200 would be a very good price. I have seen people make these deals and it end up being something very simple that costs virtually nothing to fix. You might also end up needing a new injection pump or something simple though. You could probably expect to spend around $350 for that. Still a good deal. But... if the seller "forgets" to disclose that the block froze and cracked or the crank is broke- it could quickly become a very bad deal.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
   / Value of a dead 240D #3
Dropping the sump to look and doing a compression test will be cheaper than discovering the engine is toast later, even if you end up not buying it.
   / Value of a dead 240D #4
I always ask myself this question (and we get lots of calls from people wanting us to buy their tractor "in good shape, it's just not running now and I don't want to mess with it")...If I suspected retail for a good runner might be $4500 or so (as in a nice 240D), and mine didn't run, would I offer to sell it for $2300 under that without spending a few hundred at some shop to at least find out the scope of the problem? My answer is always "No"; I would spend the relatively small amount to find out what repairs might cost. It is certainly possible for some person the answer would be yes, but would you dump a tractor potentially worth $4.5k for less than half that without having some clue as to the nature of the problem?
   / Value of a dead 240D #5
I love it when they advertise 'Ran when parked" on Craigslist.
Then you look at the photo and there is a mature tree growing up through the chassis. :D
   / Value of a dead 240D #6
Or when they say everything works good but needs engine:rolleyes: Dah! like the engine is the least of the problem :cool:
You guys bring up some very good points. I think you've talked me out of it. Too risky for my current financial situation anyway. Thanks for the input. By the way, here is a link to the ad in case someone else is feeling daring. Tractor - Yanmar 240D
   / Value of a dead 240D #8
My personal preference is: "worked the last time I used it"
   / Value of a dead 240D #9
I agree with Wayne 100%. Good point/advice.
I was just poking around on Craigs List and found a 1500D for sale.The ad read, "Everything worked great until the day my son overheated it". Must have happened recently, no tree growing through the chassis.:)
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2018 DODGE RAM 1500 (A53843)
2018 DODGE RAM...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
