value of a B7500 HST?
   / value of a B7500 HST? #11
A fine looking tractor. Looks just like the B7510 I have that I paid a lot more money for. If I could have found one like that used I would have bought it.
If you are going to be working in the woods at all you might want to add a guard over the hydraulic lines where they go across from one loader arm to the other.
To see the guard I made see B7510 FEL Hydraulic Line Guard
Bill Tolle
Bill,
I think I may take that advice. Your brush guard and hydro lines cover look great BTW. I could certainly use that Gatorade holder too! So far the only problem I've had has been with the fuel filter. I was working on moving a brush pile and a stick jumped up and lodged itself under the "out" port on the fuel filter. Well the tractor was moving forward and the front tire was on the stick, so the weak point in the chain was the nipple on the fuel filter. I was at least able to use the busted nipple and splice the fuel lines together, effectively bypassing the filter and drive out of the woods. $17 fix and all is well now. Seems like the filter could be placed just a few inches higher and it would be more protected. I'm working on some sort of cover now for the filter.
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Toro Workman Cart (A50322)
Toro Workman Cart...
3in Poly Pipe (A49461)
