Backhoe Value-Leader or WoodMaxx backhoe
   / Value-Leader or WoodMaxx backhoe #1
Kantukyboy
Wurtland ky
JD1020 MF1020
I would like to put a 3 PT backhoe on my JD1020. Have read all of the pros and cons on 3 pt and plan to build sub frame as needed. No one seems to make one for the 1020. Has anyone had any recent dealings with Value leader or WoodMaxx?
   / Value-Leader or WoodMaxx backhoe #2
Hello Kantukyboy,
Welcome to TBN. I bought the WoodMaxx WM-6600 last fall after a fair amount of research. And their price was very competitive. I've never used a backhoe before but I'm happy with it's operation so far on digging out a few small stumps and trenching for electric power to my pole barn. The only issue I had with it was an initial leaking at the PTO gearbox/hydraulic pump unit. But after talking to the service people at WoodMaxx they were quick to send out a replacement unit. My application is on a Kubota B7500 which is a small compact tractor. I did buy the heavy duty top link bracket and support frame kit that Kubota makes and recommends for use with their 3 point backhoe. I had time to change out the top link bracket but not install the support frame kit before winter set in here in Michigan. I was just careful to not stress my tractor. The support frame kit consists of 3 main pieces: a left and right side bracket that runs from the rear axle area to the front of the tractor and a cross member piece that connects the 2 side brackets underneath. One of the major problems with 3 point backhoes is the forces can twist and break the transmission (aluminum in many cases nowadays) and this kit minimizes that issue. Your JD1020 is a bigger tractor and you may not have this issue. Good luck with your search.
Thank you I am still looking and appreciate your thoughts.
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2003 JOHN DEERE 110 BACKHOE (A52707)
2003 JOHN DEERE...
2011 Ford E-250 Super Duty Cargo Van (A55852)
2011 Ford E-250...
John Deere 3032E with loader and Box Blade (A55314)
John Deere 3032E...
